{Recovered Atari Sector...}
{Unknown}
Just acquired my 3rd 4mb board (secondhand this time) in a bid to upgrade my "project - everything socketed 800xl"
here's some background of my understanding of how you can access 4mb of ram on an 8-bit atari:
Ram exceeding 48 KB on 8-bit Ataris is based around bank-switching.
A 6502 has 16 address lines. The CPU can address 64 KB total, including ram ringfenced for OS+BASIC
■ bit 0 enables or disables the OS freeing up 14 KB of RAM
■ bit 1 enables or disables the BASIC ROM freeing up 8 KB of RAM
■ bits 2 and 3 provide bank selection on 130XEs
■ bits 4 and 5 control CPU/ANTIC access (the CPU and ANTIC can bank-switch independently, which makes sense since ANTIC has its own RAM ports)allowing independent bank switching of both and allowing access to ANTIC Ram ports
■ bit 6 enables or disables XES Missile Command ROM
■ bit 7 enables or disables self-test ROM, from 0x5000 to 0x57FF; freeing up 2 KB of RAM
Most Ram expansions utilize bank-switching chips and additional memory chips, accessing more bits for bank selection.
Using 256x 16k banks (8 selection bits) - 4 MB is the maximum possible.
One or two recent expansions have a 65816 16-bit CPU, which will function in 6502 compatibility, but accesses 24 lines of address and a whopping 16mb of ram.
The main use for most ram expansions is as a ram disk, as the vast majority of software - with 130xe-specific software and demos being the main beneficiaries.
Specifications:
■ W65C816 CPU (standard 1.77/1.79 MHz clock)
■ 4MB configurable RAM
■ 512kB Flash ROM - 8 slots for paired OS+BASIC
■ 7-bit non-volatile configuration register
■ socketed MB means a solder-free installation
Compatibility:
■ 600XL - 800XL - 1200XL
■ 800XE - 130XE
■ 65XE (need to ensure clearance by raising PCB with extra socket(s)
■ 65XE - 65XEN (if 130XE board)
Installation
far too simple really,
■ remove CPU
■ remove U18 [600xl only]
■ remove MMU
■ insert Antonio board
■ connect Antonio ribbon cable to MMU socket
Memory Configurations
■ 64k RAM: zero banked, enabled 4 MB of linear memory
■ 128k RAM (130XE) 64k banked, option to enable 3 MB linear memory
■ 192k RAM (192XT) 128k banked, option to enable 3 MB linear memory
■ 256k RAM (TOMS 260XE) 192k banked, option to enable 3 MB linear memory
■ 320k RAM (Rambo XL) 256k banked, option to enable 3 MB linear memory
■ 576k RAM (Compy Shop) 512k banked, option to enable 3 MB linear memory
■ 1088k RAM (Rambo XL) 1024k banked, option to enable 3 MB linear memory
■ Axlon 2 MB: 2032k - 127x16k banked, 2 MB linear memory
■ Axlon 4 MB: 4016k - 251x16k banked, zero linear memory.
Flashing the Board - this is for adding your own OS/Basic Combinations
■ Create an ATR with SDX or MyDos to contain ANT.EXE
■ add to ATR OS BASIC rom files as required.
■ LOAD ANT.EXE
■ ANT will display current settings (dashes indicate indicate active pairs( You MUST always use pairs) expanded memory config is displayed inverse). (
■ Board is shipped with same default XL/XE OS/Rev C Basic - in ALL slots
■ to assign a new OS/BASIC pair to a slot press "F"
■ all slot-pairs will be displayed as #0 - #7 (active slot will display # as inverse video)
■ Use cursor arrow keys to highlight slot to amend.
■ Press "L" program now confirms that you wish to Load an "O" (OS) or "B" (BASIC).
■ after making your selection program will display files on D1:
■ move cursos keys to highlight chosen file and hit RETURN. - at this stage is has NOT yet been flashed
■ Press RETURN to return to previous screen - this allows you to make other selections/changes.
■ once you have everything you want pre-loaded press "F" to flash
■ you can abort at any time (except during flashing) by pressing ESC
■ once done, press ESC - computer will reboot
Important Note:
Image below from 800XL - showing 3x ICs that are removed from 600XL only.
U18 SHOULD NOT be removed for 800xl, 1200XL or XE range
Antonia 4MB Upgrade
Quick quide for the Antonia 4MB upgrade for the Atari 8-bit home computer
