Atari 8-bit Device Dimensions and Weight
A compiled listing of the dimensions and weights of various Atari 8-bit devices
Tags:
[From defunct site]
____________________
Some will find this useful, especially anyone shipping equipment or carrying out re-modelling or re-casing projects.
So here it is a list of Atari 8-bit equipment detailing external footprints, height and weight.
Model......................Dimensions - L/D/H (weight)
600XL.......................37x16x6 (1.9)
800XL.......................37x21x6 (2.2)
1200XL.....................37x31x7 (2.7)
1400XL.....................37x31x7 (2.9)
1450XLD...................37x48x15.5 (6.9)
65/130/800XE..........34x23x6 (2.2)
1050.........................30x18x8.5 (2.0)
Rana 1000..................26.5x17.5x6.5 (1.8)
Indus GT.....................28x17x7 (2.1)
Calif Access CA2001....27x17.5x6.5 (2.2)
LDW Super 2000........28x17x6.5 (2.2)
XF-551.......................30x18x6.7 (1.8)
PSUs:
Atari 800XL Brick - 1.6kg
1050/1200XL - 1.2kg
Footnotes -
metric measurements used (cm/kg)
above include ALL shielding and enclosures (deduct approx 0.3kg for shielding)
standard XL keyboard used. heavier XL keyboards add 0.3kg
Curious Fact:
converting the above depth measurements to imperial gives
600 XL (16cm) = 6 inches
800XL (21cm) = 8 inches
1200XL (31cm) - 12 inches
