Extracting Individual Files from ATRs - Using AspeQt
This is useful for adding/updating and even editing some specific files (esp BAT files) within ATRs.
[From defunct site]
Extracting Files from ATRs on a PC
Easy Method:
1] mount the ATR to AspeQt
2] to explore ATR contents - click on the rightmost icon (looks like a folder)
3] now drag n drop your chosen file(s) to any folder on your PC.
Note 1:
Files from a PC can be added to an ATR by drag n drop of file from PC folder to the AspecQt explorer window.​
Note 2:
Any files containing text content - ALL Atari line control codes will be retained.
Should you need to convert PC compatible LF/CR codes, click on the "Text conversion button" on the explorer window to turn conversion ON before your drag n drop.This will allow for direct editing on a PC​
You can also add files from your PC to an ATR by dragging and dropping a file from your PC folder to the explorer window.
Alternative Method:
1] mount the ATR
2] mount a PC folder as an Image to an AspeQt slot
3] use Atari DOS/Spartados to copy the file from the ATR image to Folder Image.
Note:
A folder image is behaves like an ATR within AspeQt, the exception being that files are written in a PC folder instead of .ATR files. AspeQt, from ver 1.01 onward includes writable folder image support
End-of-line code conversion will NOT be done when a text file is copied this way.​
