Motherboards: XL/XE Range
In-progress listing of all available XL/XE motherboards
{From a defunct Atari site}
This is just an attempt to "pull together" a complete list of all of the XL & XE Motherboards.
Machine..............Board Type/Identifiers
600xl NTSC Rev 3
.......Chleco 1983 Rev 3 embossed - after initial run, Atari stopped Chelco (China Electric Company) stamping the board​
600xl NTSC Rev 8A
......Chleco 1983 Rev 8A embossed - after initial run, Atari stopped Chelco (China Electric Company) stamping the board​
600xl NTSC Rev B
.......no monitor port​
600xl NTSC Rev X9A
...no monitor port​
600xl NTSC Rev X9B
...no monitor port​
600xl PAL
..................5-pin monitor port​
600xl SECAM
................6 pin monitor port, tv switch col/b&w, secam vsyn adjust, FGTIA secam, Freddie​
600xl Pauline
............"Pauline" engraved - proto board​
800xl Hebrew
............local factory modification Hebrew OS/keyb​
800xl Polish
............local factory modification Polish OS/keyb​
800xl Scandinavian
......local factory modification Scandinavian OS/keyb​
800xl NTSC
...............NTSC 2/3 channel switch, GTIA NTSC​
800xl NTSC
...............128k​
800xl Rev A1
.............Chelco 1983​
800xl Rev A2
800xl PAL Rev A
........GTIA PAL​
800xl PAL Rev C
........GTIA PAL Hong Kong​
800xl PAL Rev D
........GTIA PAL PBT 374​
800xl PAL Rev D
........GTIA PAL PBT 414​
800xl PAL Rev D
........GTIA PAL PBT 504​
800xlf R1
................"800XLF" embossed board, freddie MMU 484 PAL​
800xlf R3
................"800XLF" embossed board, freddie MMU 984 PAL 285​
800xl Secam X1A
..........6 pin monitor port, tv switch col/b&w, secam vsyn adjust, FGTIA secam, Freddie 4-84​
800xl Secam R3
...........6 pin monitor port, tv switch col/b&w, secam vsyn adjust, FGTIA secam, Freddie 884 800xl Secam.............128k, 6 pin monitor port, tv switch col/b&w, secam vsyn adjust, FGTIA secam, Freddie​
800xl
....................130xe board 5084 11-84 REV-R1 130XE​
65xe NTSC Rev C
...........no ECI, only room for one bank of 8x ram chips, CO21697 antic​
65xe PAL
..................ECI, 2x 8 ram banks (one populated)​
65xe PAL Rev C1
.............No ECI, only room for one bank of 8x ram chips, CO21698 antic​
65xe NAJM
...............65XEN board - 8 ram chips, ECI​
65xe NAJM
...............130xe board - 2 (of 4) ram chips, ECI​
130xe NTSC
..............4 x 32kb chips​
130xe NTSC Rev B
.....16x 8kb ram chips​
130xe NTSC Rev C
130xe PAL
................4 x 32kb chips​
130xe PAL Rev B
.......16x 8kb ram chips​
130xe PAL Rev C
130xe Secam
...........6-pin DIN, no RF​
800xe PAL Rev 1
.......ECI, 130XE board with 2 (of 4) ram chips​
800xe PAL
................ECI, 8 (of 16) ram chips populated​
XEGS PAL
.................45deg orientation of cart port.​
    1. Graham May 11, 2020
      Hi Tim
      for XEGS C100417 Rev A.
      PAL GITA & ANTIC, 2 X 21464 or equivalent 4x 32Kbit Memory chips, plus of course the separate plug in keyboard.
