{From a defunct Atari site}
RESET keys:
SHIFT: coldstart
OPTION: Basic on (when booting)
SELECT: enter QMEG menu
START: XL-mode (when booting)
QMEG menu:
ESC : exit
TAB : toggle warm/cold
A : basic/cartridge off
B : basic on
C : cartridge on
RETURN : enter monitor
SHIFT+Atari : coldstart with OPTION
START+B/C/ESC : basic/cartridge restart
CLEAR : default settings
DELETE : XL-mode
<-,->,1..8,SPACE : select drive
N : normal drive (disable speeder)
B : fast drive (enable speeder)
X : ramdisk X
Y : ramdisk Y
O : slow mode
SHIFT+O : absolute slow mode
I : disable slow mode (drive init)
SHIFT+I : reset drive
CTRL+I : disable drive cache
SHIFT+1..8 : set boot drive
S ramdisk X = single density
M ramdisk X = medium density
D ramdisk X = double density
K : function keys on/off
E : display list interrupt on/off
V : vertical blank sync on/off
G : generate DOS2.5 ramdisk on/off
L : list directory
; : list directory (with 1050 density test)
R : copy disk to ramdisk X
W : copy ramdisk X to disk
SHIFT+R : read frozen program from disk
SHIFT+W : write frozen program to disk
Function keys:
SHIFT+HELP : function keys on/off
CTRL+4 : key click on/off
CTRL+5 : cursor slow/fast
CTRL+6 : display on/off
CTRL+7 : cursor start of line
CTRL+8 : cursor end of line
CTRL+9 : cursor home
CTRL+0 : cursor bottom
CTRL+SHIFT+N : D1: normal
CTRL+SHIFT+F : D1: fast
CTRL+SHIFT+/ : D1: ramdisk X
CTRL+SHIFT+Atari : D1: ramdisk Y
Freezer keys:
CTRL+HELP : enter/exit freezer
SPACE : disable sound
CTRL+S : save snapshot to ramdisk X
CTRL+L : load snapshot from ramdisk X
CTRL+E : swap with ramdisk X
SHIFT+S : save snapshot to ramdisk Y
SHIFT+L : load snapshot from ramdisk Y
SHIFT+E : swap with ramdisk Y
HELP : exit freezer
6 hex numbers (4 digits address, 2 digits value) + return: change memory address
DELETE : delete last hex digit
CLEAR : delete all hex digits
Machine language monitor:
N : restart
Q : quit
H : hex mode on
Z : decimal mode on
#number : decimal number
$number : hex number
ADR hex/dec + ATASCII dump
ADR; hex/dec + ATASCII dump
ADR" ATASCII dump
ADR' screen code dump
ADRL disassembler
alternative addressing modes:
ADR1,ADR2 address range
ADR, 128 bytes address range*
ADR address range
ADR...$FFFF^ print data (use as a prefix)
ADR= hex+dec display of ADR
ADR1+ADR2, ADR1-ADR2 calculate sum/difference
= show address counter
ADR;xxx change memory (byte/word)
ADR"xxx change memory (ATASCII)
ADR'xxx change memory (screen code)
ADR1,ADR2 M ADR3 move ADR1..ADR2 to ADR3
ADR1,ADR2 V ADR3 compare memory
ADR1,ADR2=byte fill memory
ADR1,ADR2;xxx search bytes/words
ADR1,ADR2"xxx search ATASCII
ADR1,ADR2'xxx search screen code
ADR<SECNO,COUNT read sectors from disk
ADR>SECNO,COUNT write sectors to disk
R : show CPU registers
W=byte change
AX=byte change
XY=byte change
YP=byte change flag register
M=byte change PORTB ($D301)
ADR GO : start program
QMeg 4.4 Commands
QMeg 4.4 Commands
