{From a defunct Atari board}
As it says in the title really: A collection of quick and easy tips for use with Atari8 hardware. These are the kind of things we ALL know - but sometimes forget.
My idea is (for those of us at a "forgetful age") will somehow reduce our Homer Simpson "D'oh!" moments.
Hopefully, you'll add your own below and I'll compile them into the top post as a nice reference point for all. Don't worry if you don't have any to add. Just hope it becomes a useful thread. Oh, and for ease of reference - I'll try and keep it in alphabetical order.
800XE GTIA - Test Script
10 GR. 9=1:FOR X=0 TO 79
20 COLOR C:C=C+D: IF C=15 OR C=0 THEN D=-D
30 PLOT X,0R. X,191
40 NEXT X
50 G. 50
RUN
Above will produce a smooth pattern if OK - otherwise = faulty GTIA.
An even quicker test (thanks Fred_M) insert a Lucasfilm cartridge. distorted intro = buggy GTIA, smooth intro = good GTIA
1050 - Power, but doesn't spin up
check & re-seat main ICs U7 U8 U9 U10 U13
replace above with known working ICs - and re-test after each one.
try different PSU
test voltage between TP14 + TP15 - should = 12vDC - if nothing, look at likely cap C70
1050 - Spins...stops...spins...stops etc (2 sec intervals)
remove everything that could be unseated/unplugged - including jumpers/ICs etc
clean board
blowcompressed air through everything
reconnect all jumpers, and reseat ICs
ATARIMAX - 32-In-1 Config
SELECT @ Power Up
ATARIMAX MyIDE][ - Flash a SIDE LOADER/FACTORY RESET
Mount ATR @ D1: in APE
MYIDE cart in Atari
Power up Atari with OPTION
Follow On-Screen Options
Make MENU or SUPERMENU
ATARIMAX My IDE][ - Load ATRs
HELP - START
Find image
RETURN
“C” for COLD + ATR Boot
Strip Width
Autorun - for Basic files
■ SETUP.COM file creates AUTORUN.SYS files for BASIC- This can be done using Dos 2.5 Master Disk
menu available:
1. Change current drive number
2. Change system configuration
3. Set up AUTORUN for Boot
Autorun.sys - Re-run without Reset
■ hit RESET
■ type BYE hit RETURN
@ self-test screen
■ hit RESET
AUTORUN.SYS will start
Disable BASIC
from a READY prompt - or form within BASIC
■ type POKE 1016,1
■ hit RETURN
■ hit RESET
a warmstart will now take you to DOS
BASIC Revision
ATARI BASIC revision
You can tell which revision of BASIC you have by PEEKing location 43234.
■ enter PRINT PEEK(43234)
- 162 = Rev A
- 96 = Rev B
- 234 = Rev C
BREAK key - disable
POKE 53774,64 and POKE 16,64
POKEs must be added to your program, after every GRAPHICS, PRINT, or OPEN instruction.
Coldstart automatically
POKE 580,1
every time RESET is pressed a Coldstart is forced
Directory File
Create a file on disk of that disk's directory contents
10 DIM A$(20),B$(1280)
20 OPEN #1,6,0,"D:*.*":TRAP 80
40 INPUT #1;A$:B$(LEN(B$)+1)=A$
60 GOTO 40
80 CLOSE #1:OPEN #1,8,0,"DISKDIR"
90 B$(LEN(B$)+1)=" ":B$(LEN(B$)+1)=A$
110 M=17:FOR N=1 TO LEN(B$)/M
130 PRINT #1,B$((N-1)*M+1,N*M)
140 NEXT N:CLOSE #1
b]Dos - access without OPTION[/b]
you forgot to hold down OPTION key on powerup?
■ POKE 1016,255
this will take you direct to DOs and BASIC will NOT be installed
DOS 3 - File Managment Error Fix
first you need to identify if you have the newer or older [buggy] Dos 3
■ PRINT PEEK(3889)
78 = latest version, 76 = early (buggy) version
■ to fix a "76" type this program and save to disk
10 POKE 3889,78OKE 39
23,78OKE 3943,78
26 POKE 3929,76OKE 38
95,76OKE 3901.77
30 POKE 3935,77OKE 39
55,77OKE 2117,240
■ RUN it
■ exit to DOS >> with a blank disk >> I - initialise disk >> Y to write FMS.SYS.
■ Copy all files (but not FMS.SYS) from your Master disk to new disk.
You now have a version 78 Dos 3 disk
Dos - Indentify Version
■ in BASIC @ READY prompt
■ enter PRINT PEEK(3889) and hit RETURN
0 = SpartaDOS 2.3e
13 = DOS 4.0
15 = SpartaDOS 1.1
19 = Atari 2.5
76 = Atari 3.0
78 = Atari 3.0
89 = SpartaDOS 3.2d
108 = MYDOS 4.0
207 = OSS OS/A+ 4.00
221 = MYDOS 4.50
238 = OSS DOS XL 2.3
244 = Atari XE
■ enter PRINT PEEK (1804) and hit RETURN
0 = OSS DOS XL 2.3
124 = Atari 2.0s
Drives 3 & 4
Although Dos will work with 4 drives you need to tell it that you have more than 2 drives.
Flag 1802 needs to be set correctly
a standard setup will allow for 2 drives, therfore location 1802 has it's lowest two bits set at 3 - ie 0011
using a POKE command you can change the flags in location 1802, thus,
2 drives = 3 = 0011
3 drives = 7 = 0111
4 drives = 15 = 1111
you can access 8 drives, but each additional drive will need 128 bytes of memory
Duplicate Filenames
where you've somehow created two different files with the same name.
■ create backup of file on another disk.
■ Type POKE 3118,0 and hit RETURN key
■ Go to DOS. hit START button
■ Option E - rename file (affects only first file)
■ Press B to return to BASIC. POKE 3118,184. You you should now have two different files with two fifferent filenames.
Filenames - Upper/Lower case
■ POKE 3818,48OKE 3822,123.
FORMAT disk from BASIC
■ enter X=USR(3352)
to format a disk from a READY prompt
GTIA Identification
10 GRAPHICS 9
20 GOTO 20
black screen = new version. blue screen = old version.
IDE Plus 2.0 - Access Config Menu
>> Boot with START
Config Menu = START + RESET
SDrive (ARM) - Boot Sequence
0. Power on atari, what while loader starts.
1. assign game to D1:
2. Press 'Reset'
3. Press 'Option'
4. Release 'Reset'
5. Release 'Option'
International Character Set
■ enable = POKE 756,204
■ disable = POKE 756,224
Keyboard Disable
■ POKE 16,255
prevents people messing when you're away from your desk
Keyclick Disable
■ disable = POKE 731,255
■ re-enable = POKE 731,0
Memory Wipe
■ enter POKE 202,1.
add above POKE to a program and it'll be wiped from memory when ended, hitting BREAK, RESET or any return to READY prompt will completely wipe your program from memory.
MEM.SAV workaround
You can create a MEM.SAVE file from BASIC
■ enter X=USR(5947)
XL - press RESET after disk access has stopped
400/800 will return an ERROR 9 once MEM.SAV file has been successfully saved
OS version - 400/800 thanks Fred_M
? PEEK(65528)
34 = PAL rev. B (not found anywhere yet)
214 = PAL rev. A
221 = NTSC rev. A
243 = NTSC rev. B
255 = NTSC first OS (not found anywhere yet)
OS version - XL/XE thanks Fred_M
? PEEK(65527)
1 = XL/XE OS rev. 1
2 = XL/XE OS rev. 2
3 = XL/XE OS rev. 3
4 = XL/XE OS rev. 4
10 = XL/XE OS rev. 10
11 = XL/XE OS rev. 11
59 = XL/XE OS rev. 3B (Arabic)
POKE - Permanent
PERMANENT POKES
Any POKES that you make in immediate mode (READY prompt) can be made permanent.
■ type DOS to go
■ at DOS menu
■ option H - this will rewrite a modified (with POKES) version of DOS to disk.
Print Disk Directory from Dos
■ type A
■ hit RETURN
■ type: ,P: RETURN
Print Files - from Dos
A quick way to print files to screen or printer - direct from Dos
■ turn on printer
■ from Dos - select : option C - COPY FILE.
■ at prompt enter D:FILENAME.EXT,
after , enter either
P: - for printer or S: - for Screen
screen scrolling can be paused suing CONTROL + 1
SIDE2
With BUTTON = Ult 1Mb will check if pressed
W/O BUTTON = Ult 1Mb will ignore if pressed
BUTTON OFF = cart active
BUTTON PBI BIOS = disabled cart
**BUTTON forces cart off, allowing you to swap ATRs
*** PBI BUTTON checks button regardless of when enabled or disabled in BIOS
PBI Enabled? Must also set
SIDE W/O or SIDE WITH BUTTON
SWITCH = UP SDX = ENABLED
SIDE2 - as an XEX Loader
Prepare CF CARD
add games
Insert CF card to SIDE 2
move switch to UP position (ultimate users – disable PBI DEVICE in ultimate bios)
power up atari ATARI
Select/enter chosen file
restart/reset computer press switch at SIDE2 and RESET on ATARI
SIDE2 - Sparta DOS Mode (hard disk interface)
Prepare CF CARD
Adjust switch to LOWER position (ultimate 1mb users – disable PBI DEVICE + SDX in ultimate bios)
Power up ATARI
Sparta Dos with SIDE2 drivers swill boot. when CF card is correctly prepped partition list will be displayed.
SIDE2 - ATR loader (ult 1mb users only)
HELP+RESET to access ultimate bios
Enable Sparta DOS, PBI device with BUTTON SUPPORT
PRESS+HOLD “L” to activate SIDE2 loader
SELECT *.atr file + ENTER
for multidisc software, press SPACEBAR to mark file as D1:
select subsequent disks and SPACEBAR to mark *.atr file it will be marked as D2: , D3: etc
Enter to restart
SIDE2 switch reassigns disk mapping for *.atr files
D1 D23
1:
SIDE2 - CF Prep
Power up ATARI
sdx bootup should take you to a D1: prompt
FDISK
select initialize disk
"scanning bus"
select IDE1 - CFcard *****
contents will be erased? Y/N - Y
FAT32 partition Y/N
assign your APT = 256
select unallocated disk
Create New - 65537
continue creating until CF partitions all allocated as desired
when done - DISK - Write Table
once "partition table updated", select DISK, EXIT, Y
D1: format
SPARTADOS FORMATTER
Unit = A, Volume = leave blank, Skew = n/a, Density = DD 512, Mode = Sparta, Tracks = n/a
Optimize = On
65535 sectors, 512 BPS, ********* bytes,
format = n/a,
Unit = A should change to "B"
Select "B" Build Directory
returns you to D1: prompt
A B etc - D1: D2 etc
Smooth Scrolling
with any program loaded into BASIC
■ POKE 622,255 ($26E)
■ LISTwill result in a smooth scroll
■ exit to DOS - command is still enabled
■ disable using POKE 622,0.
Ultimate 1Mb - Config
HELP @ Power Up
Ultimate 1Mb Default Settings
1088 / stock XL - DIS DIS DIS DIS DIS 7 CAR3 CAR3
Ultimate 1Mb - Flashing/Resetting Firmware
Boot with HELP
Set ram = 1088
SIDE hardware = OFF
SDX = ON
S to SAVE
Remove SIDE cart
Copy Rom Files & UFLASH.XEX to folder
Mount Folder in ASPEQT as D1: “MOUNT FOLDER”
Boot computer…SDX will load
Type UFLASHXEX
Navigate to BIOS, PBI Bios & Loader (each in turn) hitting RETURN and navigating to relevant ROM file
Wildcard Character
if you'd like to replace the standard "*" wildcard with a character of your choosing
■ POKE 3783,
with ATASCII value you prefer
Word Count
Ever wanted to count the words in your text files?
10 OPEN #1,4,0,"D:filename"
20 TRAP 100
30 GET #1,B
40 IF B<>32 and B<>142 THEN 30
50 GET #1,B:IF B=32 OR B=155 THEN 50
60 COUNT=COUNT+1
70 GOTO 30
100 PRINT "Word Count = ";COUNT
XL - BASIC Rev/Version Identifier
?PEEK(43234)
162 = Brown Cart = Rev
96 = RevB = stock XL
234 = RevC = late XLs
Quick and Easy Tips (Atari)
Collection of quick and easy tips for use with Atari 8-bit
